Porsche 3.0 case renew
  • Porsche 3.0 case renew
    A buddy from Chicago who runs with NASA GTS3 had a bearing failure last year and I got the case for a good cleaning and some upgrades. I will update as I progress, first it will be shuffle pinned, piston squirters replaced, center main bearing oil passage enlarged etc. so far just got it all apart oil plugs removed and case halves surfaced.
    Im not sure what im looking at, but im pretty sure its pornographic.
      Since you already have a boner here's half the motor! :)
        Reaming the thru bolts:
        Case halves matched for the shuffle pin install:
          Porn
          A big Ford 4x4, a Deeeeezle BMW and a air cooled flat six
          PCA# 2014080243
            This part is done, all the pins are in and it lines up perfect. The purpose of this is to keep the main journals from fretting. Normally the case is only held in alignment with pins at the flywheel and the nose bearing this is now supported at each main.
              Old piston squirters removed and the new ones installed. These are expensive little bastards!
                noice
                WSAC,PWC
                00 Golf
                71 Westy
                  So Purdy!
                    Working on the heads now, bead blast, new guides, 3 angle seat cut etc.
                      Sweet...
                      MKII Golf-GTI's... once you've owned one your cursed !!!
                        fantastic. and as always, thanks for sharing. I love these threads of yours.
                        Your friend Raven
                        92 Corrado VR6t
                        05 Audi A6
                        90 Miata (because racecar)
