Wow, you are in deep now.
Project: Keep on Truckin' Rabbit pickup
Lookin good.
Need any floor pans? I bought complete pans but only used the back half.Joe
Originally posted by joezeeuw View PostLookin good.
Need any floor pans? I bought complete pans but only used the back half.--paul--
MKV R32, 78' Suns Out Guns Out, 81' Caddy,
2012 Tiguan SEL 4Motion, Failure--Rollin on 20's
well.. since i last updated
Cut the front end off the pickup and got to work
IMG_3198 by paul lehman, on Flickr
IMG_3202 (1) by paul lehman, on Flickr
IMG_3212 by paul lehman, on Flickr
you can see drivers rocker & inner rocker area gone
IMG_3242 by paul lehman, on Flickr
many nights working like this haha
IMG_3223 by paul lehman, on Flickr
getting thing cut out i needed cut out and getting the front clip ready to go on
IMG_3259 by paul lehman, on Flickr
230 by paul lehman, on Flickr
test fit to of the clip on.. screwed and tack welded to check fender, hood fitment
256 by paul lehman, on Flickr
324 by paul lehman, on Flickr
drivers inner area with the clip in place
379 by paul lehman, on Flickr
32818102287_e766eb3c95_o by paul lehman, on Flickr
some of the measurements i used plus the Bently
IMG_9847 by paul lehman, on Flickr
Started filling all the holes in the bay...
Untitled by paul lehman, on Flickr
cut out the drivers floor pan and some of the inner rocker area. The inner rocker area was patched from pieces i had from the red rabbit (Now you can buy inner rocker replacement panels from Raybuck.com)
Replaced the drivers pan and checked to make sure the seat still fit
I plan on running a Rear rabbit bench seat up front or trying to put something together for one at some point like this...
I picked up some front seats and cut them up to fit a bench on that i have already... but may find a better one.
Next up i pulled the windshield with he help from Tegan
pulled to fix these areas
cut up a replacement panel to use for patches
all welded in
cut out some of the passenger side area to patch with a panel also
Then Jan. 2020 i planned to work on the truck more!
picked up more lighting for my garage
Before
After
Finally started doing the pass. rocker areas
Outter rocker cut out, replacing inner rocker areas
Tegan helps when she can
patching floor pan
Made some wooden wheel stands.. crib things
Dropped the gas tank for more room
Next up is fixing this mess... Both sides like this
Rear inner frame rail rocker area
everything cut out
Starting to rebuild it
Picked up a newer welder.. Harbor Freight Titanium MIG 140 Super happy with it so far
Then got into the outter rockers
Cut out the rear arch to replace it.. no before photos of the rust
Also fixed the rocker area behind the arch but no photos.. i have video progress on youtube i'll post the links at the end.
Stripped the passenger fender because it was a nice day outside
Dropped the axle and leaf springs to make room
Going 4-link bag setup in the rear
Welded in the drivers floor support and fixed the passenger side front area
Ran out of MIG gas and couldn't get my filled due to the Shelter in place... So borrowed one from work :p
Next up the lower portion of the radiator support
Filling the tow hook hole
Spun the truck around to start the Passenger side
Cut out the rear area on the pass side also
Tegan helping more
replacing the drivers arch
arch and rocker in
Fixing rear area
Stripped the drivers fender
Started sanding the paint down on the driver side..
Here is the start of my Youtube project videos.. i go into more detail on them at times
--paul--
My plans on the paint are this...
Gonna sand everything down and pull any dents i find
Epoxy primer the truck
Everglass the welded patch areas
body filler
2k high build
seam seal any areas needed
seal
then paint
Gonna be learning on all this stuff as i go as well haha--paul--
Yesterday i threw the RS's on the axle and put it into place to get an idea on specs for the 4-link
Not all the way slammed because the bump stops are in the way but wanted to get an idea on it.
More on that later
Thats pretty much all up to date!--paul--
Dang dude! I have been following on Facebook. I can’t wait to see this thing on the road. I have been eying that welder. I’m leaning more towards the multi process one thoughNick-
Present:
Audi S5, Audi Q5
Past:
B5 Passat, MKIII GTI Vr6, Audi Coupe Quattro
