Mk2 problems
  • Mk2 problems
    Mk2 gli 2.0 16v. Anyone want to come help me figure out what sensors I need for this thing? And to help me finish my wildwood "front" mk4 "rear" breaks? The only part I have not replaced it the proportion value on the rear beam. Won't bleed.
    I'm just west of Lansing.
    Don't know much about MK2s but good luck!
    90 Audi Coupe Quattro 20vt
    08 VW Touareg - VR6
      I just realized, MIVE is back! And, not much traffic in this forum. :( I've got a picture of engine sensors and locations, but it seems I can't upload it. vanman9 what sensors in particular do you need to know?
      I've never had any problems bleeding the stock brakes on my Mk2 16V. I put it up on jackstands, and use the Motiv bleeder to lightly pressurize the system and push fluid through. If I'm really energetic I'll put a jack under a rear corner to raise the rear beam to activate the rear prop valve to let more fluid flow. (Rear prop valve is basically load/ride height sensing.)
      1987 VW GTI 16V
