G60 cooling trouble
  • G60 cooling trouble
    New pump and thermostat.
    I spent the extra money for the "good" pump with the full size brass impeller.
    Car was/is running about 220° F and the cooling fan doesn't seem to come on when it should.
    Lower radiator hose is cold, so i replaced the thermostat again.
    That didn't help.
    I unhooked both upper and lower hoses and stuck a garden hose in it to check for a clogged radiator.
    Flow through seems normal.
    Did I get a bad pump?
    I suppose I should see how much is flowing back to the overflow.
    My thought is the impeller in the pump is spinning on the shaft.
    Opinions?
    Could be air in the system preventing circulation.
      I suppose I should go through a thorough system burp to be sure that's not the issue.
      I have never really had an issue with it in the past. I can usually get it bled out easily by running it with the cap off and squeezing the hoses a few times.
      Probably prudent to be 100% sure though.
        if the lower hose is cold it's probably air. My G60 is my least favorite to replace coolant in because of how hard it is to get the air out.
          I've never had a problem with my G60..fill the system from both sides and let it run vented till it gets up to temp.
            Like steve said, on the earlier 8v motors, I would fill the radiator and the block, then top off from the resivoir. run the car uncapped until it came up to temp, then cap and burp a few times adding coolant as needed.
